Menu
HTML CSS JAVASCRIPT SQL PYTHON JAVA PHP HOW TO W3.CSS C C++ C# BOOTSTRAP REACT MYSQL JQUERY EXCEL XML DJANGO NUMPY PANDAS NODEJS DSA TYPESCRIPT ANGULAR GIT POSTGRESQL MONGODB ASP AI R GO KOTLIN SASS VUE GEN AI SCIPY CYBERSECURITY DATA SCIENCE INTRO TO PROGRAMMING BASH RUST
JS Reference
JS by Category JS by Alphabet
JavaScript
JS Arrays JS Boolean JS Classes JS Dates JS Error JS Global JS JSON JS Maps JS Math JS Numbers JS Objects JS Operators JS Precedence JS Promises JS RegExp JS Sets JS Statements JS Strings JS TypedArray
Window
Window Object Window Console Window History Window Location Window Navigator Window Screen
HTML DOM
HTML Documents HTML Elements HTML Attributes HTML Collection HTML NodeList HTML DOMTokenList HTML Styles
alignContent alignItems alignSelf animation animationDelay animationDirection animationDuration animationFillMode animationIterationCount animationName animationTimingFunction animationPlayState background backgroundAttachment backgroundClip backgroundColor backgroundImage backgroundOrigin backgroundPosition backgroundRepeat backgroundSize backfaceVisibility border borderBottom borderBottomColor borderBottomLeftRadius borderBottomRightRadius borderBottomStyle borderBottomWidth borderCollapse borderColor borderImage borderImageOutset borderImageRepeat borderImageSlice borderImageSource borderImageWidth borderLeft borderLeftColor borderLeftStyle borderLeftWidth borderRadius borderRight borderRightColor borderRightStyle borderRightWidth borderSpacing borderStyle borderTop borderTopColor borderTopLeftRadius borderTopRightRadius borderTopStyle borderTopWidth borderWidth bottom boxShadow boxSizing captionSide caretColor clear clip color columnCount columnFill columnGap columnRule columnRuleColor columnRuleStyle columnRuleWidth columns columnSpan columnWidth counterIncrement counterReset cssFloat cursor direction display emptyCells filter flex flexBasis flexDirection flexFlow flexGrow flexShrink flexWrap font fontFamily fontSize fontStyle fontVariant fontWeight fontSizeAdjust height isolation justifyContent left letterSpacing lineHeight listStyle listStyleImage listStylePosition listStyleType margin marginBottom marginLeft marginRight marginTop maxHeight maxWidth minHeight minWidth objectFit objectPosition opacity order orphans outline outlineColor outlineOffset outlineStyle outlineWidth overflow overflowX overflowY padding paddingBottom paddingLeft paddingRight paddingTop pageBreakAfter pageBreakBefore pageBreakInside perspective perspectiveOrigin position quotes resize right scrollBehavior tableLayout tabSize textAlign textAlignLast textDecoration textDecorationColor textDecorationLine textDecorationStyle textIndent textOverflow textShadow textTransform top transform transformOrigin transformStyle transition transitionProperty transitionDuration transitionTimingFunction transitionDelay unicodeBidi userSelect verticalAlign visibility width wordBreak wordSpacing wordWrap widows zIndex
HTML Events
HTML Events HTML Event Objects HTML Event Properties HTML Event Methods
Web APIs
API Canvas API Console API Fetch API Fullscreen API Geolocation API History API MediaQueryList API Storage API Validation API Web
HTML Objects
<a> <abbr> <address> <area> <article> <aside> <audio> <b> <base> <bdo> <blockquote> <body> <br> <button> <canvas> <caption> <cite> <code> <col> <colgroup> <datalist> <dd> <del> <details> <dfn> <dialog> <div> <dl> <dt> <em> <embed> <fieldset> <figcaption> <figure> <footer> <form> <head> <header> <h1> - <h6> <hr> <html> <i> <iframe> <img> <ins> <input> button <input> checkbox <input> color <input> date <input> datetime <input> datetime-local <input> email <input> file <input> hidden <input> image <input> month <input> number <input> password <input> radio <input> range <input> reset <input> search <input> submit <input> text <input> time <input> url <input> week <kbd> <label> <legend> <li> <link> <map> <mark> <menu> <menuitem> <meta> <meter> <nav> <object> <ol> <optgroup> <option> <output> <p> <param> <pre> <progress> <q> <s> <samp> <script> <section> <select> <small> <source> <span> <strong> <style> <sub> <summary> <sup> <table> <tbody> <td> <tfoot> <th> <thead> <tr> <textarea> <time> <title> <track> <u> <ul> <var> <video>
Other References
CSSStyleDeclaration JS Conversion
HTML DOM Element offsetTop
Example
Get the offsetTop position of "myDIV":
const element = document.getElementById("myDIV");
let pos = element.offsetTop;
Try it Yourself »
Get the positions of "myDIV":
const element = document.getElementById("test");
Let pos1 = element.offsetTop;
let pos2 = element.offsetLeft;
Try it Yourself »
More examples below.
Description
The offsetTop property returns the top position (in pixels) relative to the parent.
The returned value includes:
  • the top position, and margin of the element
  • the top padding, scrollbar and border of the parent
The offsetTop property is read-only.
Tutorial:
CSS Box Model
The offsetParent
All block-level elements report offsets relative to the offset parent:
  • offsetTop
  • offsetLeft
  • offsetWidth
  • offsetHeight
The offset parent is the nearest ancestor that has a position other than static.
If no offset parent exists, the offset is relative to the document body.
See Also:
The offsetLeft Property.
The offsetWidth Property.
The offsetHeight Property.
The offsetParent Property.
The clientTop Property
The clientLeft Property
The clientWidth Property
The clientHeight Property
Syntax
Return the top offset position:
element.offsetTop
Return Value
Type Description
NumberThe top position of the element, in pixels.
More Examples
Create a sticky navigation bar:
// Get the navbar
const navbar = document.getElementById("navbar");
// Get the offset position of the navbar
const sticky = navbar.offsetTop;
// Add the sticky class to the navbar when you reach its scroll position. Remove the sticky class when you leave the scroll position.
function myFunction() {
  if (window.pageYOffset  >= sticky) {
    navbar.classList.add("sticky")
  } else {
    navbar.classList.remove("sticky");
Try it Yourself »
Browser Support
element.offsetTop is supported in all browsers:
Chrome Edge Firefox Safari Opera IE
Yes Yes Yes Yes Yes Yes
Contact Sales
If you want to use W3Schools services as an educational institution, team or enterprise, send us an e-mail:
sales@w3schools.com
Report Error
If you want to report an error, or if you want to make a suggestion, send us an e-mail:
help@w3schools.com
W3Schools is optimized for learning and training. Examples might be simplified to improve reading and learning. Tutorials, references, and examples are constantly reviewed to avoid errors, but we cannot warrant full correctness of all content. While using W3Schools, you agree to have read and accepted our terms of use, cookie and privacy policy.
Copyright 1999-2025 by Refsnes Data. All Rights Reserved. W3Schools is Powered by W3.CSS.
